- Oct 14, 2016
- 16
- 6
Ok guys I ordered 4 of the latest mid-range Cantonk IP cameras.
I wanted to check quality, inside and outside. Possible point of failures and of course image quality.
These were the ones ordered and that I now have in my possession,
KIP-200SL20H (IMX323, HI3516C)
KIP-400SL20H (OV4689, Hi3516D)
KIP-200CD20H (IMX323, HI3516C)
KIP-400CD20H (OV4689, Hi3516D)
Now should I just do a write up or make a unboxing and testing video? The SL20 are dome cameras, the CD20 are bullet. The sensors are pretty much the same, only the form factor is different.
It should be noted that I just had a Cantonk failure in one of my installations, only one went down but I need to dig deeper into the cause. It powers on but I cannot connect to it.
