- Mar 11, 2014
- 43
- 11
I have a Hikvision ds-2cd2532f-iws that has a stuck IR cut filter, so I'm looking for a replacement (unless someone has a fix). I like the small mini-dome form factor, so I've been looking at these Cantonk cameras:
http://www.cantonk.com/Info/View_pro.asp?id=1125
My questions are... does anyone have any personal experience with these cameras? I need at least 2MP, but the viewing distances are 12' or less, so I'd trade better night vision for more MP's. The camera has quite a few sensor and processor options, not sure which is the best choice. I'm also concerned with IR reflections off the dome, a problem the Hikvision certainly does not have. Lastly, the camera is spec'd with a 3.6mm lens, the Hikvision with a 2.8mm lens in 1080P 16:9 mode gives me about 98 deg view angle which I really need. I've asked Cantonk if they can supply wider angle lens, but have not gotten an answer back yet. I may just buy another Hikvision, but the price of the Cantonk is way less, and I'm impressed with the night vision images of the other turret Cantonks I have.
Joe
Joe
