On the FedEx truck out for delivery, getting a jump start on the review.
Specs copied from catalogue
1/3" OmniVision 4MP High‐resolution CMOS Sensor,
Hisilicon Hi3516A Main Stream: 4MP@30fps; With IR‐CUT
H.264/H.265 Compression
20X Optical Zoom (f=4.7mm‐94mm)
7" HD-IP High Speed Dome Camera
Weatherproof Outdoor IP66
¢22x6PCS+¢16x5PCS IR LEDS, IR Range: 150m
Pan Range: 0°~360° Continue; Tilt Range: 0°~93°
Flip Pan Speed: 200°/sec; Tilt Speed: 100°/sec
Preset Points: 220
Guard Tours: 3
Groups Guard Points: Max.16 points
TCP/IP, HTTP, FTP, RTSP Support P2P Support
Power Adaptor: DC12V/4A
Lightning Protection: Transient Voltage 6000V
Size of Package (LxWxH): 32x32x43(cm)
Weight: 7.5Kgs
I had them pull the exact CMOS info, OV4689
I did NOT request the jpg capture feature to be disable, the camera is for weather watching, play, and outdoor security when not used for the others.
[Personal Experience]
My dealings with the company were smooth and the sales rep was very friendly and helpful. There was no sales push and even though there is a 12hr difference they were very prompt in responding, usually first thing in the morning for them, late evening for me. If the products are good quality and preform within my expectations I would recommend them without hesitation.
Order placed 4/20/16
Order shipped 5/2/16
FedEx Delivered 5/6/16 (3 days earlier than expected delivery)
There was a few Chinese Holidays during that time frame, also the earthquake in Japan incident.
Arrived in excellent condition
This thing is HUGE!
Preset Points: 220
Guard Tours: 3
Weight: 7.5Kgs
This thing is HUGE!
