I have about 15 IP cameras hooked up to the Hikvision NVR DS-77161NI-14. The NVR is on a different subnet than the main network, and this is a router-on-a-stick vlan. When i http into the NVR from the LAN, the live view will fail every single time. I can access the cameras from outside the network as i did port forward for app streaming, and i dont think its a routing issue. When i put the NVR back into the default vlan, the live view works fine. Do i need to setup access list on the subinterface? Anyone had this problem?
