- May 19, 2022
- 8
- 0
Hello,
I've stayed on BI version 5.7.6.8 (5/19/2023) and Codeproject.ai version 2.0.8.0 for a few months now because any time I upgrade either software to any version that is higher than the versions just mentioned, the ai detection just breaks. Even if I just update one and not the other. I'm kind of stuck on these versions since May and I've been looking everywhere for an answer. I have noticed people experiencing similar errors when using the license plate reader feature, but I've never used it and always check to see if it somehow got enabled, but it's not. They also seem to be experiencing other error numbers, not the 404 error I keep getting.
It gives "ai: error 404" code on the alert pane on the left hand side, on the alert itself under the word "motion" for each alert. Normally, this would show what the ai found (person, car, etc). The icons on the top right of the alert that represent the ai findings are also not available. I've attached the error messages as well as how it looks normally, under the previous versions mentioned.
I've tried going from 5.7.6.8 to a few of the newer different versions (didn't document which ones, but I've tried stable and newest releases). I've tried going from Codeproject.ai version 2.0.8 to 2.1.9, and the latest 2.1.11. I've tried reinstalling the software and it doesn't seem to do anything differently. Still see the same error any time I'm past those two software versions.
If anyone has any insight to this, I would appreciate some help. Thanks!
