This is my first post on this forum so I'd like to start by saying hello, thank you for having me and that this forum has already been of great help to me. Thank you!
Background Info:
I have 6 Lorex LNE9292B cameras which I understand is the same as the Dahua N85FJ6Z. I have upgraded all the firmware on my LNE9292B's to the most recent firmware (IPC-HX5XXX-Volt_MultiLang_NP_Stream3-USA_V2.840.18LK005.0.R.230526) on Dahua's site for the N85FJ6Z.
I have followed this thread to set up automatic control of black and white and IR.
Issue:
Of the six cameras ALL of them state compatibility of 4k@30FPS and ALL of them had initial maximum settings of 4K@20FPS. The drop down for FPS only went up to 20 when 4k is selected. I have been able to get 5 of them to show 30 FPS and select it while at 4K. I don't know how. Just playing around with the settings and it just showed up on the five cameras. The sixth camera I'm having a hard time getting this setting.
Steps I've Taken:
Import Backups from other cameras. The import fails.
Tried using this API
Additional Information:
Running this API
What I'd like to do is find anyway to get this setting changed. I'm not sure if my understanding of the getConfigCaps API is correct or if I can even change the MainFormat to one that supports the settings I want.
Any help greatly appreciated by this n00b.
Background Info:
Issue:
Steps I've Taken:
http://172.28.16.8/cgi-bin/configManager.cgi?action=setConfig&Encode[0].MainFormat[0].Video.FPS=30 to set the FPS. "Error. Bad Request!"Additional Information:
Running this API
http://<IP ADDRESS>/cgi-bin/encode.cgi?action=getConfigCaps&Encode[1].MainFormat[0].Video.Width=1920&Encode[0].MainFormat[0].Video.Height=1080 the results, shown below, seems to tell me that there are three MainFormats; MainFormat[0], MainFormat[1], MainFormat[2]. MainFormat[0] supports 4k@30FPS, the others support 4k@20FPS.
Code:
caps[0].BitRateRange[0]=3
caps[0].BitRateRange[1]=8192
caps[0].ExtraFormat[0].Audio.CompressionTypes=PCM,G.711A,G.711Mu,G.726,AAC
caps[0].ExtraFormat[0].Video.resolution=0x0
caps[0].ExtraFormat[0].Video.BitRateOptions=64,512
caps[0].ExtraFormat[0].Video.BitRateSuggested=256
caps[0].ExtraFormat[0].Video.CompressionTypes=H.264,MJPG,H.265
caps[0].ExtraFormat[0].Video.FPSMax=20
caps[0].ExtraFormat[0].Video.H264Profile[0]=Main
caps[0].ExtraFormat[0].Video.H264Profile[1]=Baseline
caps[0].ExtraFormat[0].Video.H264Profile[2]=High
caps[0].ExtraFormat[0].Video.MaxROICount=4
caps[0].ExtraFormat[0].Video.ResolutionTypes=D1,VGA,CIF
caps[0].ExtraFormat[1].Audio.CompressionTypes=PCM,G.711A,G.711Mu,G.726,AAC
caps[0].ExtraFormat[1].Video.resolution=0x0
caps[0].ExtraFormat[1].Video.BitRateOptions=1536,8192
caps[0].ExtraFormat[1].Video.BitRateSuggested=3072
caps[0].ExtraFormat[1].Video.CompressionTypes=H.264,H.265
caps[0].ExtraFormat[1].Video.FPSMax=20
caps[0].ExtraFormat[1].Video.H264Profile[0]=Main
caps[0].ExtraFormat[1].Video.H264Profile[1]=Baseline
caps[0].ExtraFormat[1].Video.H264Profile[2]=High
caps[0].ExtraFormat[1].Video.MaxROICount=4
caps[0].ExtraFormat[1].Video.ResolutionTypes=1080P,720P,D1,VGA
caps[0].MainFormat[0].Audio.CompressionTypes=PCM,G.711A,G.711Mu,G.726,AAC
caps[0].MainFormat[0].Video.resolution=0x0
caps[0].MainFormat[0].Video.BitRateOptions=512,5120
caps[0].MainFormat[0].Video.BitRateSuggested=1536
caps[0].MainFormat[0].Video.CompressionTypes=H.264,H.265
caps[0].MainFormat[0].Video.FPSMax=30
caps[0].MainFormat[0].Video.H264Profile[0]=Main
caps[0].MainFormat[0].Video.H264Profile[1]=Baseline
caps[0].MainFormat[0].Video.H264Profile[2]=High
caps[0].MainFormat[0].Video.MaxROICount=4
caps[0].MainFormat[0].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P
caps[0].MainFormat[1].Audio.CompressionTypes=PCM,G.711A,G.711Mu,G.726,AAC
caps[0].MainFormat[1].Video.resolution=0x0
caps[0].MainFormat[1].Video.BitRateOptions=1441,8192
caps[0].MainFormat[1].Video.BitRateSuggested=4683
caps[0].MainFormat[1].Video.CompressionTypes=H.264,H.265
caps[0].MainFormat[1].Video.FPSMax=20
caps[0].MainFormat[1].Video.H264Profile[0]=Main
caps[0].MainFormat[1].Video.H264Profile[1]=Baseline
caps[0].MainFormat[1].Video.H264Profile[2]=High
caps[0].MainFormat[1].Video.MaxROICount=4
caps[0].MainFormat[1].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P
caps[0].MainFormat[2].Audio.CompressionTypes=PCM,G.711A,G.711Mu,G.726,AAC
caps[0].MainFormat[2].Video.resolution=0x0
caps[0].MainFormat[2].Video.BitRateOptions=1441,8192
caps[0].MainFormat[2].Video.BitRateSuggested=4683
caps[0].MainFormat[2].Video.CompressionTypes=H.264,H.265
caps[0].MainFormat[2].Video.FPSMax=20
caps[0].MainFormat[2].Video.H264Profile[0]=Main
caps[0].MainFormat[2].Video.H264Profile[1]=Baseline
caps[0].MainFormat[2].Video.H264Profile[2]=High
caps[0].MainFormat[2].Video.MaxROICount=4
caps[0].MainFormat[2].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P
caps[0].SnapFormat[0].SupportIndividualResolution=false
caps[0].SnapFormat[0].Video.resolution=0x0
caps[0].SnapFormat[0].Video.CompressionTypes=MJPG
caps[0].SnapFormat[0].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P,D1,VGA,CIF
caps[0].SnapFormat[1].SupportIndividualResolution=false
caps[0].SnapFormat[1].Video.resolution=0x0
caps[0].SnapFormat[1].Video.CompressionTypes=MJPG
caps[0].SnapFormat[1].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P,D1,VGA,CIF
caps[0].SnapFormat[2].SupportIndividualResolution=false
caps[0].SnapFormat[2].Video.resolution=0x0
caps[0].SnapFormat[2].Video.CompressionTypes=MJPG
caps[0].SnapFormat[2].Video.ResolutionTypes=3840x2160,3072x2048,3072x1728,2592x1944,2688x1520,2048x1536,2304x1296,1080P,1280x960,720P,D1,VGA,CIF
