Hi...new here...but have learned a lot from reading and implementing an older WINIC NR32P8-8 with this forum's help...
This summer i upgraded the older firmware from a 3.x version to 4.30.005/210413...following the advice to upgrade in steps...
Some quirks, but more stable...
Email setup is a problem...I use an RR email via spectrum - and use pop to send/receive...on all computers, phone, etc...this does not require encryption or authentication...
No matter what i try, it simply can't get past "test failed"...
The NVR is ip 192.168.1.3 and the main router is 192.168.1.1 ...doesn't work when i auto-configure DNS for 192.168.1., or manually use 8.8.8.8 or the DNS from spectrum...
I am using guarding vision app - and that is fine...
Is this firmware related - or something else?...
if the firmware is unstable should i upgrade to another release?...if so, what...
thanks...R
thanks...R
