Hi,
Our church has 30 HIK cams on a DS-9632NI-ST. It is FW version V3.3.4 build 150811, and has been rock solid for 10+ years. I purchased two new DS-2CD2H43G2-IZS cams from J&R. Using the NVR I activated them and changed their IP to be within the range of the NVR (the NVR has a Cisco POE switch, which is what our other cams are powered by). The NVR sees the cam on the Camera Setup list screen, but there is a - sign instead of a play button, which says 'unknown error'. I can not see the cams on the multicam screen.
I can log into the cams directly and see the live view.
Also, I can use IVMS4500 and go to Maintenance and Management tab, and add the cameras manually at the bottom of the list, under my NVR. Then I can drag their icon over to a spot on the Live View screen, and see the cam. But, in doing so, I dont think it is streaming to the NVR, it is just streaming to the workstation, so its not being recorded.
Suggestions?
Suggestions?
