Events SubscriptionsThe events request funky code is the issue. I've reset them still nothing.
are you sure the clips box is not set to display only the selected camera or a specific group or folder? is it set to all?Yeah, I watched them trigger and turn red. At the same time watched the clips box and nothing.
yes but is the little green camera selected to show only the selected cam?It's set to show all.
what are the record settings for that specific camera and specific profile...a camera can be trigger but it wont record if the record settings not right.yes but is the little green camera selected to show only the selected cam?
format issue?It's as if these two particular cams have a format issue or something.
if you can see it live its matching.It's as if the video from the cam isn't matching with the BI encoding ya know.
you have something set incorrectly.Yep everything else works fine, it's only when they are triggered.
