fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,409
In your router you need to create a distinct EXTERNAL port for each camera. (you can change the port in the camera, but it is not needed with most cameras)..for example set external port 8001 to go to the ip address of your second camera port 8000.Hey Kyle it worked for one of the cameras but what should I use for the other, I tried to used the same and it said that already exist and I could not connect.
For example if you second camera is 192.168.1.136
In your cisco router,
Set the start port to 8001 end port 8000 and 192.168.1.136 for the ip in the router.
In the app, use the External ip address and port 8001 NOT 8000.
Do this for each camera, just change the start port, 8002, 8003 etc and ip address.
You dont have to change anything on the camera.
Also, disable port forwarding for 80 and 554 on the first camera, its not needed and a security risk.
