Hello,
I have read about 20 different threads on this forum and elsewhere regarding my issue, but I cannot solve it:
I have two hikvision cameras, and I cannot load the firmware via tftp, the cameras never even check the tftp server according to the tftp log and wireshark.
Thank you for whatever help you can provide.
- I am using tftpd32 server by PH. Jounin(I tried solarwinds also) set to port 69.
- I upgraded to 5.2.3 via the web interface and would like to go back to a previous version.
- My ip address on my laptop nic is 192.0.0.128.
- I tried two different laptops with different brand nics.
- I disabled all other network connections including wireless prior to opening tftpd32
- digicap.dav is in the same directory.
- All firewalls are off and disabled.
- I can connect and download digicap.dav using a linux box via a direct cable connection from the tftp server without any problem.
- I have tried pressing and holding reset after reconnecting power on for 15 and 30 seconds multiple times.
- I have tried unplugging and replugging the cameras about 30 times.
- The camera has 192.0.0.64 when it is connected.
- SADP confirms that they default back to 192.0.0.64
- only one camera is connected to my pc at a time directly with an ethernet cable.
- I can connect to the web interface just fine at 192.0.0.64 with no problems.
- I installed wireshark and winpcap, and looked for tftp traffic and I never see the cameras searching for my tftp server.
- One camera is the 3mp ds-2cd2432f-iw the other was bought from a different vendor and has no label, but SADP says it is the same.
