Can't enable FTP and NAS storage destinations
wrybread
Pulling my weight
Sep 12, 2018
260
123
San Francisco
When I go to Settings -> Storage -> Destination, the checkboxes to enable FTP and NAS are disabled... Is there some secret to enable those?
Also, when I record from the Live tab, it appears to be recording (the icon changes), but I can't find the recording anywhere.
Camera is a SD49225T-HN with a 128 gig SD card installed.
Also, when I go to Settings -> Storage -> Destination -> Local, the "used capacity" doesn't change on my SD card (holding steady at "45.2M/118898.9M"), so I don't think it's recording anything to the card either...
Hello,
under schedule, did you actually order the IPC to record anything? Or only Motion Detection (and your camera did not see any motion detections). Some features are bit complicated (at the first time), but you'll find your way!
Good luck!
CC
