First attempt at this so please forgive the ignorance. Pretty sure this is a I don't know what I don't know situation and when it comes to networking that's pretty much everything.
Camera: IPC-HFW5241E-Z12E
Switch: IPCamPower 16 Port POE Network Switch W/ 2 Gigabit Uplink Ports
I have 2 computes hooked up to the switch in the regular ports (not uplink). The router is connected to the switch via the uplink port. The camera is in a 3rd regular port. Both PC's have ConfigTool installed. Via ConfigTool one of them can see the camera the other cannot. On the PC where ConfigTool can see the camera I also have Blue Iris installed. Blue Iris cannot see the camera. ConfigTool has a amber colored bar under status and fails to change the IP or Get Device Info. I cannot access the camera via the default IP address in a web browser on either PC. The router see's both PC's but not the camera.
When plugged into the switch or hitting the reset button I can hear the camera start up as it adjusts the lens.
Both PC's can access the internet.
Both PC's as I understand it are in the correct IP range 192.168.200.xx
Both PC's match the subnet
I have reset the camera. No change.
Any help is greatly appreciated.
