I just bought an Imou Cruiser 4MP and I cannot change the FPS.
I provisioned/initialized the device using the Imou Life app (Android) and proceeded to make more configuration changes using SmartPSS on my desktop. I am able to adjust the bitrate, resolution, and other encoder settings, but I cannot change the FPS from 25 to 15, which is what I want.
I change the setting in SmartPSS and the device seems to accept the changes, but when I open the stream in BlueIris or any other RTSP viewer, I am locked at 25fps. Even changing it down to 1fps I get 25fps.
Additionally, it appears I am unable to change FPS for key intervals as well. Problem applies to both main and substreams. It looks like I am locked to:
Main: 25fps / key interval 75 fps
Substream: 15fps / key interval 15fps
Any ideas or suggestions? Firmware bug?
Edit: Upon further testing, it seems none of the settings other than resolution and encoder type (H264/H265) actually work. Confirmed this in SmartPSS, Amcrest Surveillance Pro, and Dahua Config Tool.
