Using what video player?All my attempts only connect to the main stream which is 1280x720.
Not when there is no info to help provide an answer.Any ideas?
Using tinyCam Pro. Tried changing channels in advanced settings, but that had no effect. I see that with some cameras, a different port can be assigned to the secondary stream, but my FW doesn't provide that option.Using what video player?
With what RTSP URL?
That's not an option I've come across.I see that with some cameras, a different port can be assigned to the secondary stream
Does this camera have the 'Single stream / triple stream' selection option in the web GUI, if so, which is selected?
Suggestion:
Assuming the camera is ONVIF compatible - query it with the very good Windows tool 'ONVIF Device Manager' from sourceforge.net
ODM will automatically find ONVIF devices on the same IP segment as the PC. Give it logon credentials at the top left of the window.
The Profile page will show you what profiles are available, and allow you select the one of interest when there are multiple.
Then the Live Video page will show you the needed RTSP URL to access it, at the bottom of the page.
Longse specs say that model is ONVIF 2.4, so what @alastairstevenson said ^^^^ is the way to go.
If that doesn't crank your tractor, try this I found at, miracle of miracles, Longse Support by Googling "longse LBH24S200 rstp URL" ==>> here.
Try your RTSP URL using VLC player, found ==>> here.
It states (substitute "colon p" for the pink smiley face, go to the link above to clarify):
_______________________________
"How to use RTSP stream to view network IP camera?
If the network IP camera support RTSP stream, its address is written as below:
rtsp://user nameassword@ip address:rtsp prot/0 main stream <<== EDIT; they spelled 'port' as 'prot'.
rtsp://user nameassword@ip address:rtsp prot/1 sub stream
rtsp://user nameassword@ip address:rtsp prot/2 third stream
For example:
rtsp://admin:[email protected]:554/1
From the above address you can get,
The username for login is admin
The password for login is admin
The RTSP port default setting is 554"
Thanks so much! That was annoying!
:p
(Imagine Johnny Carson's voice here) => "Ed, I did not know that."available from the + icon in the editor.
