Relocated NVR to remote location, windows 10 computer. Computer and NVR connected to same switch then to router nothing helps.
I can access NVR directly, through phone using android app dgmss, and through computer using Smart PSS.
No matter which browser I try... Edge, IE, Chrome, Firefox it asks me to install plugin (webservice). After it is installed and I try to access the NVR, it asks to install it over and over.
I also installed NACL Web Plug-in . I get web service app to open, but it always says invalid password. (same one I use on NVR)
I would like to eventually do remote access, but if I can't get in locally then...
Any help would be appreciated.
