Hi all I have a hikvision 7608 8 POE port nvr. I have 6 Poe ONVIF 2 compatitable cameras.
My internal network address is 192.168.0.1/24
the IP address on the nvr is 192.168.0.15/24 gateway 192.68.0.1
the internal IPv4 address on the nvr is 192.68.1.1
any IP camera attached to the nvr is in the 192.168.1.x range.
now here is the issue, if I connect the IP cam to myPC I am able to view a live feed, if I attach it to the nvr it detects the protocol ONVIF but there is a triangle which says unknown error.
is there anything I could do to resolve or even troubleshoot this?
i have tried many different things and possible solutions, changed cable, IP address, network address read manual over and over etc, still no solution.
its probably a simple thing which I'm missing out.
any help will greatly be apreshiated.
kind regards
Sam
kind regards
Sam
