Hi,
On my new camera DS-2CD2365FWD-I I am not able to retrieve the image from the app IP Cam Viewer on my Android. It's working on my other Hikvision camera, and I have compared all settings - I think
Any suggestions where to look for the right settings?
I have also tried to install the app Hik-Connect, but not sure if it's working without setting up Hik-Connect on the camera - the error is Device is offline.
If it for some reason is the app which is causing the problems, because of unknown camera model - can you then recommend a good one?
/Kennet
/Kennet
