- Aug 26, 2015
- 46
- 9
I have 12 HikViison Cameras of varying types and all exhibit the same symptom in BI - they pause every few seconds. You can both observe it in real-time and in recordings. And the system is no slouch - idling at sub 5% most of the time. I am trying to get smooth recordings so i can calculate the approximate speed of vehicles by time from known marker-to-marker but this is not possible with this behaviour as the clock keeps ticking with identical frames at the "pauses".
Typical example: DS-2CD2683G2-IZS at 3840*2160 with variable BR and 20 FPS with 20 i-Frame-interval with Mx BR set to 8192 and using H.264 - latest firmware V5.7.10 build 220830
Every few seconds both the live view and recording just pauses repetitively
BI is set to use the secondary-stream for live and is direct-to-disc. Increased buffer all the way up to 40MB and tried Decoder Compatibility Mode. Hardware Decode is Intel+VPP
SystemSpec:
Dedicated Intel Core i7-12700K with 32GB DDR4-3200 Low-latency RAM. Windows installed to dedicated 250GB primary NVMe Drive. Databse is also on the primary drive. The BI NEW primary drive is a super-fast RAID-0 2TB NVMe drive (2x1TB Samsung drives) and that offloads to STORED: an 18TB Seagate 7,200RPM EXYNOS Drive. There is an unused NVIDIA GTX 1650 Super installed, which I am planning to use with DeepStack at some point. The box runs headless with a dummy HDMI dongle and I access it via licensed Teamviewer v13. But even when not accessing the recordings exhibit the symptoms.
OS is Windows 10 pro 22H2 fully Service Packed and BI release 5.6.2.10 x64
The CPU rarely goes above 5%
I did not have this problem with BI 4 on way lesser hardware
Cameras are connected to a Cisco Gigabit PoE Switch
Anyone have any ideas I can try? Thank you
SystemSpec:
