I record 2 separate streams from the same camera (They are the same camera but call A & B as they have two separate configs is BI, NOT Main & Sub Stream)
It would be very helpful for this and other situations & in the past if a clip from elsewhere or different camera could be played through a different config's settings for testing & tuning.
basically..
A: records on even the smallest movement
B: is much more selective for LPR and only want to process limited recordings. A>B zone & DeepStack after.
I have clips from A that show the car approaching but B, 5% of the time does not record, would be great to run A's clip through B's settings, testing & tuning & see why it did not pick it up.
There is a fine line between recording & alerting on many unwanted but not missing those I do.
I have tried adjusting, testing with own car but just takes so much time & different cars, vans etc. times of day. So much easier if I can just review those that have not worked.
basically..
