I am using an hikvision camera and getting the mjpeg stream via http using this -> http://<i-address>/ISAPI/Streaming/channels/102/httpPreview
The problem is that i can see the stream only one one single devide/window.
Even if i open up 2 windows one next to the other, on the first one i see the stream normally, on the second i get an error.
Is it possible to stream the mjpeg stream to multiple sources?
Thanks a lot
Thanks a lot
