Hi
I'm looking for a setup for my house that's easy to install and manage, Ideally I'd like to have the ability to:-
1. Use power over Ethernet cameras - if I'm having to run a cable to them for power, I might as well use the same one that takes data down
2. A mix of dome camera's so they can pan/tilt and bullet style so some are fixed - ideally 2 of each
3. Night vision - something I think is pretty standard
4. A system that can upload to a website eventually - I don't mind having a central control box with a HD in
5. Accessible from iPad/laptops
6. motion detection
The software interface has to be easy and something modular may be an option as I'm pretty technical but require a kick start here... - could anyone advise on a system that would meet my needs?
Many thanks
Sean
6. motion detection
Many thanks
Sean
