I itm Getting the hang of it May 1, 2017 198 44 Greater London, UK Feb 16, 2023 #1 I'm looking for an indoor camera with a zoom feature which can be controlled from the BI web UI. I was thinking about the Reolink E1 Zoom. Does anyone know if the optical zoom can be operated from the BU web interface? https://www.amazon.co.uk/dp/B07K7HPCVJ?ref=emc_p_m_5_i
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,140 Alabama Feb 16, 2023 #2 Consider this ==>> Reolink E1 Pro PTZ doesn't work on Blue Iris (offical Response) but note post #11; @mickiete says it works for him. Reactions: bp2008
I itm Getting the hang of it May 1, 2017 198 44 Greater London, UK Feb 16, 2023 #3 TonyR said: Consider this ==>> Reolink E1 Pro PTZ doesn't work on Blue Iris (offical Response) Click to expand... Thanks - I had already read that thread. It concerns the E1 Pro. rather than the E1 Zoom???
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA Feb 16, 2023 #4 Post #14 says it works with E1 Zoom PTZ controls. Technically he said E1 Pro but in post #18 he corrected himself. Reactions: TonyR
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA Feb 16, 2023 #5 Read for yourself though before purchasing. I only skimmed the topic and did not dig deep.
I itm Getting the hang of it May 1, 2017 198 44 Greater London, UK Feb 16, 2023 #6 bp2008 said: Post #14 says it works with E1 Zoom PTZ controls. Technically he said E1 Pro but in post #18 he corrected himself. Click to expand... Ah - thanks for pointing that out - I hadn't noticed it!
