The NVR can store license plates It says " dedicated license plate capture camera". Does the camera B52IR-Z12E S2 work for the purpose?
TIA
 TIA
That NVR can do 'AI by device' functions, including 1ch 'video metadata'. In video metadata it does try it's own LPR detection.The NVR can store license plates It says " dedicated license plate capture camera". Does the camera B52IR-Z12E S2 work for the purpose?
TIA
Is there a NVR that works like how you do with BI for the z12e?No it does not. The Z12E is used by us to manually read the plates, but it is not designed as a plate camera.
You would need an ANPR or ALPR camera that can actually read and log the plates. Something like this:
Mini-Review - EmpireTech LPR413-Z3
Would this camera capture out to 120' or so? I have a 437 and would like to get this to grab plates from the other direction.ipcamtalk.com
I have not had time to check on metadata. Does it need lots of setting and fine tune? How well is it during the day?That NVR can do 'AI by device' functions, including 1ch 'video metadata'. In video metadata it does try it's own LPR detection.
I don't know if this would work at night when only the plate & headlights show on an LPC camera's image.
I use this function on a spotter camera (handy to search every human/vehicle/bike that has gone past).
'Video metadata'.@Mark_M What function are you using on the NVR to get car, people, etc information? Are you using it with IVS? Does it really slow down your NVR? Thank you sir.
It works during the day fine. At night I think it would not work properly.I have not had time to check on metadata. Does it need lots of setting and fine tune? How well is it during the day?
I don't use this camera for LPR. I enabled video metadata for this spotter camera.What else did you do? Like what setting in the camera GUI? I tried this on my neighbors NVR and it never read plates.
Almost finished writing this reply lol....... Now I have finishedMark does the camera you are using that one have Video Metadata enabled?
I had to enable it on the Z4 itself to get the stats and I think the database on the NVR under AI Search (non-AI NVR)
