Can i use BI with a stand alone NVR?
observant1
Getting comfortable
Dec 2, 2018
479
883
alabama
Should i just migrate all my cams to the BL PC? I'd like to play with the BI PC with a few cams hooked to it, and keep my NVR with a few cams hooked to it.
Is it functunial in that set up?
Reactions: Flintstone61
In all likelihood, you can pull the video feeds right from your NVR into it.
In BI, you select add camera and put the IP address of the NVR into the IP address location. Put in username and password and hit find/inspect and let BI do its thing.
Then about halfway down is a pull down for Camera number and pick camera 1 and then hit ok. The camera should show up. Then add camera and the select copy and copy this camera and then change the number 1 to a 2 and repeat for your cameras.
So download the BI trial and give it a try and see if you like it better than the NVR.
Reactions: observant1
I've got the full version of BI 5. Just need time to learn it.
Just an FYI...BI has excellent built-in "Help"....the " ? " up at the top left.
