Hi all.
Setup:
Dahua NVR 5216-16p-4ks2e
6 cams (all directly connected ethernet) - all Dahua
Asus router Rt-AX86U
20 port managed switch
I would ideally like to set up one or two cams in places I can't reach with ethernet cable (for various reasons). These places would be within my network's wi-fi range. If this is possible, I may add a wifi doorbell too.
So is there a way the NVR can "see" a wireless cam?
- Can i somehow set up an ethernet switch with some sort of wireless capability, then onto the NVR via ethernet?
- Can I make use of 2 spare USB ports on the back of my router?
Other ideas? Compatible cams?
Setup:
