I bought all Hikvision from milkisbad and have run into a problem. I have LTN8832 that is connected to a 4 port gigabit switch. Then from that switch it is hooked to three 8 port poe switchs in different locations. On the 8 port switch you can only use 7 ports and 1 uplink port. Can I take one of the 7 and split it with a 4 port gigabit poe switch? I need 8 cameras in that location. Hope this makes sense.
