Can deleted files be imported into database
waya
Jul 12, 2018
2
sf nm
Hello,
I recently had a few protected files deleted by BI when my hard drive filled up. I successfully recovered the files and would like them to be available in the BI database. Is there a way to get BI to include them again?
Thanks!
Hello,
Thanks!
yes, regenerate the database. also it should not delete if its protected.
Thanks, they are back. The files were marked as protected, I wonder how they got deleted?
you sure they were not simply "flagged"?
regardless, if you need a file, its always best to not only protect it but export or copy it to a USB drive in case of drive failure.
Reactions: Mike
