Are these purely for power then ,powering 2 cameras from one poe port or can they send data and power down the one line?
Both power and data
I use this. As long as your POE source can provide 30watt AND all your cameras uses less than 30watt, it'll work fine.
I want to use the Poe from my NVR. I need three inputs and one output. Then one input and three outputs for the cameras. I have now ordered them and will test them.The one you bought does not support PoE. There should be plenty that would work if you look here: Amazon.de : poe passthrough switch
Not everything in amazon search results will be compatible. You need specifically something that has PoE input and PoE output. It may say PoE extender or PoE repeater. You also need its maximum power limit to be enough for 3 cameras.
As has been mentioned, these ^^^^ are essentially POE-powered switches but retailers have an affinity for the term "POE repeater" and "POE extender."I want to use the Poe from my NVR. I need three inputs and one output. Then one input and three outputs for the cameras. I have now ordered them and will test them.
Sorry for the question, but I haven't done this with an extender before. If I use port 5 to power three cameras, will one of them automatically connect to port 5 and will I have to set the others to the correct port myself?As has been mentioned, these ^^^^ are essentially POE-powered switches but retailers have an affinity for the term "POE repeater" and "POE extender."![]()
