I installed my first cameras last night (Dahua Starlight) and set up Blue Iris. So far so good mostly, but a few problems.
I hope you can click to view my timeline in detail:
Both cameras are set to record when triggered. You can see the lime green camera recorded most of the night despite only half a dozen moments when it detected motion. It then recorded motion at 07:38 and when that trigger ended it stopped recording.
Then at 07:15 motion was detected on the slate grey camera, it started recording and hasn't stopped since :/
Below are my relevent settings, so not sure what I've set wrong:
Couple more questions. How do I manually delete footage?
What happens if I delete footage direct from the computer storage folder and not from within Blue Iris? Will BI realise files are deleted and remove them from the timeline?
Thanks!
Thanks!
