I have had my setup running for a few days now and I've noticed that every now and then it stops recording. The colored bar at the bottom sometimes goes blank, and other times it stays lit up. The only reason I know they stop recording is because I go back to an event and some or all of the cameras are black.
Is this a common issue? Am I doing something wrong? As soon as I restart the program it starts recording again... until it doesn't.
Does the cameras color mean/do anything specific? How do most of you set them up?
How long should I keep the clips for? I check the alerts every day, will it slow anything down if I keep them around for a few days, or should I archive them every day?
My set up: 4x Dahua Starlight Varifocals all hooked up to a Ubiquiti 24 port POE switch. My computer is a Dell Optiplex i7-4770 3.40ghz, 8GB, 4TB WD Purple, windows 10 64bit, never gets above 20%.
