Hi everyone,
I am in the process of upgrading our cameras onboard a boat (currently using Lilin cameras, which are horrendous).
I require the following cameras:
- 8 x PTZ dome cameras (both interior and exterior use)
- 4 x HD weather-resistant cameras (wide angle is a bonus) - these also need to be ceiling mounted, not wall mounted, as they will be fitted underneath spreaders.
So far, I have been looking at Amcrest, Dahua, Milestone and Axis.
Since they will be in a harsh marine environment, they need to be 100% watertight and pretty robust to stand up to the elements.
Cameras of interest so far include:
The cameras will be running off either Frigate, Scrypted or Blur Iris.
Budget for the HD cameras should ideally be around 2000 euros or under, and the dome cameras around 1000 euros or under - unless the price can really justify the quality.
Based on the above, I would really appreciate any advice on available options that I could have a look at.
Thanks so much in advance!
