Normally i always use the built in poe ports of the nvr. I have some installations where switches are used. So the camera's are set as static ip, then added to the nvr. However, each year, after the client changes modem ( cuz of change isp ) the ip range changes, so the cameras have to be reconfigured.
I can enable dhcp, and add them, but as soon as they get another op adress, the nvr will show offline. However i have seen situations, in which the nvr automaticly adds a camera.. OR is there maybe a setting to Settle that camera, that when the ip adress changes, its being re-added automaticly ? That will be a lot easier. As the NVR is alrdy set DHCP ( cloud )
Thanks
Thanks
