Camera under the porch
bp2008
Staff member
Mar 10, 2014
12,886
14,482
USA
I moved last year, and wanted my cameras to be more discreet than they were at my previous house (big turret and bullet cams mounted all over the siding).
This mostly meant using small and inconspicuous cams to watch the driveway, and those aren't great for ID shots.
So I was thrilled when I realized there was plenty of room to tuck my old Dahua whatever-Z5 starlight cam under the porch to look up at people as they approach. It is like the opposite of having a camera that is too high. This one will see you watching the ground.
The lighting is a bit tricky since it sees mostly sky. So I set it to shutter priority, 0-4ms, and Backlight to BLC.
This works pretty well even at night because I turned off the camera's built-in IR and put a separate illuminator nearby to keep the glare down, as there's a lot of nearby porch, ground, and steps to reflect IR back and fog it up at night.
Ah, yes...the "CrotchCam"! Love it!
This is nice If someone is trying to hide there face by looking down with a cap..
I have one by front door Approx 2 feet above ground. Can you share what the installed camera looks like ?
Wow, that's a tough shot looking up at the sky like that. Does the sun come more into play depending on the time of the day? Is it maybe a northern view where you don't get a silhouette pic because the sun is right behind the person?
It is unfortunate that the best zoom cams are varifocal, because autofocus is awful at night in this position.
Sure, maybe later.
Yes, the sun moves directly through the camera's FOV in the morning. I can't find any person captures at that time but here's a bird.
