Camera type? with ethernet connection inside camera body??
Andykev
Jun 21, 2021
63
34
SF Bay Area
I am new. What I am seeking is a model of IP camera which has the ethernet POE connection inside the camera. 10 years ago we installed GeoVision, I thought they had a design where you could run ethernet cable
thru a small hole in the wall and then attach the plug, then it plugged into a port inside the camera.
What I am trying to do is find a good camera that doesn't have the three lines (ethernet, audio, power) dangling on the cord.
Thanks. I have a lot to learn, and couldn't find any topic/posts on this subject.
There are some dahua/hik domes that do this, usually the higher models. Domes bring much bigger IR reflection issues. Just use the junction box made for the camera.
Thanks. I am likely going to use bullet style, and was considering the Annke NC800.... but it's a guess on my part. Some people I know running home systems use a mix, Hikvision and Dahu cameras. I just
was looking to avoid drilling large holes in the wall of my stucco house.
NC800 – Acme 4K UHD Full Color Night Vision PoE IP Security Camera with f/1.0 Super Aperture
Image Sensor
1/1.2" Progressive Scan CMOS
30% off on annke's website now .. still too dear for me :(
Here are reviews of two cams that seem to fit your requirement.
