Camera triggers, but alerts never sent out
DanLins
Jun 17, 2016
33
1
Logisaf IP cam, worked fine until a couple months ago with Blue Iris. Something happened to make it so that on triggers, it will record and take snapshots ok, but it never send out an alert. When I test the alert (email), it sends one out dutifully. SMS (on Sprint) never sends out a test response.
Not using groups. I've set the motion sensor to both extremes , different make times also, no go. No highlighting, no advanced Object detection or zones used. Cancel Shadows is the only box checked in the Motion Sensor window. And Motion Sensor is the only box checked in the Trigger window.
Any suggestions for a fix on this?
Thanks,
DanL
