biggen
- May 6, 2018
- 2,957
- 3,397
As far as external IR is concerned, here is a review of the Axton PoE IR unit that I did: Axton PoE Illuminator review
I will test the wash back again. one thing I failed to recognize (you reminded me when you said flush) was the other cameras were mounted at 15 feet. I could not get them flush with out being noticeable. These cameras will almost be at plate level, so I may get lucky on this install. thanksI know it is not a new install, I am simply pointing out that you possibly do not need to hide them and simply paint them the color of the post and strap them to the mailbox post and probably be fine and thus be able to use the camera IR...just giving you suggestions based on what others have done as that is what you asked for....
But it can be hidden as well and still use the camera IR if you mount the lens flush to the outside of the object you place it in.
@samplenhold provides a great summary of what he did here:
New to LPR? Considerations Before You Begin
Thought I would throw together a post on my experiences so far with LPR in an effort to help others that are considering running down that rabbit hole. There are some practical considerations you should know about LPR. I am approaching this from the position of using Blue Iris and Plate...ipcamtalk.com
And where did you hear that? Not the NEC...some local municipal "electrical" inspector?Cat and 110/220v cant be in the same trench by code.
That is the code here. Unless your running conduitAnd where did you hear that? Not the NEC...some local municipal "electrical" inspector?
That's the part I was hoping hear, as I designed, installed and maintained underground electrical installations for traffic signals and street lighting for over 31 years.Unless your running conduit
I will keep that in mind for the future, thank you. This post was not about electrical code or direct burial vs conduit. simply stated, Last option I would consider is a light. Added cost of conduit, bigger trench, direct burial wire if no conduit, cost of the light post, the impact on the neighborhood--the only one with an driveway light by the street, all these decisions I can make my self and is personal preference. Also, based on other peoples comments, looks like IR is the way to go in this application. Make the conduit for power a moot issue.Run conduit. If you're digging a trench anyway, it's no harder to drop some plastic conduit in than the bare cable. The ends are the hardest points positioning them so you don't get water ingress. But that's another subject and one I'm not familiar with.
Use armoured electrical cable designed for burial even if using conduit. I'd conduit both cables.
As above, check local codes and requirements. Waterproof sockets for electrical are cheap enough. Biggest cost is armoured cable and conduit and the biggest issue isthe cable is more difficult to fit - usually has steel wire wound around the inner conductor layer that needs to be cut away at the ends to enable you to make the connection. It also isn't very flexible. I have exterior grade armoured LAN for my pc (not cctv) as it was easiest to run it outside then back in and under the floor to the main telephone point. It was slightly awkward to fit for this reason.
No, its pitch black at night. You get the plate and nothing else at night.do you have alot of street light in that application? I did some testing with a similar camera and it did not perform well.
I think he is saying that the last option he would consider is adding a visible light. In other words, he won't do that.Bit confused. You're still going to have to run cat 6. A trench is trench. As for visible light, probably not legal anyway. You cannot shine a light down a road into the eyes of drivers. Ir is the way to go. As other have said look at the number plate reading threads as it's a specialist art and you will see only the plate and nothign but the plate at night. If you want anymore details of the car, you need a 2nd over view camera.
overview camera is already in place as noted in 1st post. No flood light implied as I used term spilled. Just a normal residential post lamp at the driveway entrance. yes...a trench is being dug. Conduit or 2nd trench will not. A trench was not mentioned in 1st post as it was not in scope of the question. Hope this helps.Bit confused. You're still going to have to run cat 6. A trench is trench. As for visible light, probably not legal anyway. You cannot shine a light down a road into the eyes of drivers. Ir is the way to go. As other have said look at the number plate reading threads as it's a specialist art and you will see only the plate and nothign but the plate at night. If you want anymore details of the car, you need a 2nd over view camera.
