- Mar 30, 2015
- 1
- 0
I plan on setting up a semi-automated (on a schedule) recording rig with Blue Iris and a single camera to record basketball games on a full length court. The camera will be mounted on the short side. It needs to capture audio, have as high res as possible and have a wide fov to cover the entire court. My goal is have it such that, for example Blue Iris will start and stop recording then automatically upload that footage to either an ftp site or somewhere like Dropbox. My budget for the camera is around 300. Do you all see anything wrong with this system or do you have any suggestions?
The distance from the camera position and the side of the court is probably about 20'. My guess on the needed for is 150-160 degrees.
My understanding is the camera can run cat5 or 6 to a router or switch/hub then to the computer and carry audio and video. Is that correct? And would that be an IP camera. I'm not against going wireless as long as it was a solid reliable signal. It is a clear shot to the computer location and measures about 40'
Thanks in advance
Andrew
Thanks in advance
Andrew
