Hello,
I'm looking for suggestions for a suitable camera for a lake view in the woods of Maine. Initially, the usage would be capturing an image every minute or so and displaying it publically on a website. At some point, I may opt to also make available a live video feed if I can find a way to proxy a single camera feed to a public server so multiple people can watch.
Deployment environment:
In order to test the location, I was going to set up a temporary pole mount 6-8' off the ground to confirm a good location and height. For a PoE solution, I was going to run direct-burial cable on the ground while testing.
Thank you for any suggestions,
-Bill
- The camera location is from 100' to 200' to router/switch.
- Lots of trees and brush between the camera location and the router as this is the back woods of Maine.
- May eventually install as many as 3 or 4 such cameras around the property for different views.
- Trenching and burying Cat 5e cable and conduit through the woods is going to be a pain.
- Cellular cameras are not an option as the coverage is weak or non-existent.
- Varifocal lens is preferable to tweak the view at installation time.
- Style can be bullet or turret.
- Not considering a PTZ camera as there's lots of trees and brush on either side of the view.
- 4K resolution for still images at least.
- For night vision, there's not much to see across a half-mile of water, so a camera with good low-light capability is more important than good IR or color night vision.
- Optional lens distortion correction feature to eliminate the fisheye effect.
- External solar panel available.
- In addition to motion detection, there should be a timer feature so an image can be returned every 1 to 5 minutes.
- 2K resolution for still images.
- Distance is far enough to the router that I probably need to use some long-range access point mounted outdoors.
- Non-proprietary API, e.g. support HTTP GET to pull an image or SFTP to push images.
- So far, I've not found any battery-powered camera that meets the above criteria. A continuously powered camera might work but there's no power at the camera locations.
-Bill
