Sweet, I found this site...someone actually found the serial port....
poking around I can actually change the subnet of the Cams but it doesn't look like the cameras are getting their IP from the NVR, must be hard coded on the camera? I don't see a dhcp daemon running in the process list.
And I was able to change the subnet that the NVR gets to a 172.16.0.x/255.255.255.0 and it's able to route packets as long as the PC IP address is in the 172.16.0.x pool. If I try to ping the NVR from 172.16.3.x/16, it doesn't work.
