[Moved the thread from the cameras forum]
Hello,
I am looking for some advice regarding camera placement at my house. I have some limitations as to where the cameras can be reasonably placed, so I am looking for feedback to get the decent coverage and ID ability. The idea is to get decent coverage without a ridiculous amount of super obvious cameras.
Below is the front of the garage, which faces a 47' long (30' wide) driveway.
The soffit height of the garage is 10'.
At location #1, I already have a Dahua IPC-T5442T-ZE (4MP 2.7 - 12 mm varifocal turret). It blends in super nicely and hardly noticeable from the street.
My other mounting locations are 2 and 4, with a possibility of mounting a cam at #3 (but I need to find the right form factor, so it can blend in while being pointed straight out).
I was thinking another 544T2-ZE at #2, and adjust them both to cross each other and both "zoomed in" a bit.
But that will leave a large gap right by the garage doors.
I have 2 existing ethernet drops going to garage attic, with a possibility of maybe adding 2 more (1 has to service the backyard though).
Challenges:
Here is an image from #1 it at 2.7 mm.
And here is #1 zoomed in to cover only the drive
#1 2.7 mm at night
The porch has a Nest Doorbell for now, and I can live with it for now.
Back of house pics
View from location #8, at half of the mounting height:
For the back, I am thinking.
1. Another IPC-T5442T-ZE at location #8, zoomed into towards the gate. That location is services via garage attic drop. I can potentially run more drops to the garage through conduit I installed.
2. TBD cam at location #7, which will point towards the other gate. This location is services by house attic drop, of which I have two. This might be a 5442T-ZE bullet equivalent.
3. TBD cam at location #5, looking down side of the house, basement window, AC. Possibly another 5442T-ZE bullet equivalent, or even turret mounted sideways.
What will be missing is any sort of an "overview" cam for the back yard.
Options here are to trench some ethernet from the basement (where the switch is), and mount a wide angle lens cam at/near the fence looking at the house.
Alternatively, I can run the same cable from a the basement location, behind the downspout, and up to a wide angle lens cam at location #7. Would have to use conduit to protect the cable, but that depends on the looks.
I also have 3 Ubiquiti G3 Bullet cams from the previous house. That's before Ubiquiti pissed me off and I went to Blue Iris
They have a wide angle lens with a FOV just slightly narrowed than the Dahua cam I have.
For those, I am probably going to use those inside (1 in garage facing side door, 1 in mechanical room), though one of the bullets has an IR extender and could be used as an "overview" cam.
Wow, this came out to be a long post and a lot of pics. I hope I did not lose everyone.
Any feedback or suggestion are really appreciated, going to be placing an order with Andy soon
Hello,
Challenges:
- At night, bright lights are present from 3 garage coach lights and the post light. Post light mainly affects the camera at #1.
- The third garage bay is set back from the front elevation, creating a blind spot
#1 2.7 mm at night
Back of house pics
