This is in continuation to a cable post I made several weeks ago.
I needed to get some pictures of the surroundings before I ask more questions.
This is what I’m trying to capture from a camera mounted on the telephone pole mentioned earlier in this post.
I would like to be able to see the front door area and the left side of the building, where the covered golf cart is sitting. The distance from the front door to the pole is roughly 75ft. This doesn’t take into account the camera being mounted high on the pole which will add distance.
I have a camera above the front door but it doesn’t show enough due to being so close. It’s right above the dust to dawn light. I also have 2 cameras on the pole to the rear of the building. One faces the cart while the other captures the rear door of the building.
I have all Hikvision bullet cameras at this location currently but think I would like to go with a turret for this connection.
What would be the best camera for this application? I’m also open to other placement ideas as well.
Here’s the original thread asking about the cable.
https://www.ipcamtalk.com/showthread.php/10636-100ft-cat5e-cable-run_strain-releif
Thank You.
Thank You.
