I am finishing out a brightly lit (12 3000 wat LED UFO Fixtures) indoor pickleball court with 4-6 IP cameras to monitor ball in/out calls and 2-3 IP cameras for analysis and review of games. Looking at this thread here High speed swing analysis camera setup - Golf Simulator Forum I saw that cameras like these could work for the review of ball in/out calls in a pickleball game. In one of the latest televised PPA events, the commentators announced that they had upgraded to 120 fps cameras to better review in/out calls. This seems consistent with what the guy used in the golf swing analysis to minimize blur while being fast enough to catch the contact of a club with a golf ball. However, a big difference I have is that my line call cameras will cover more distance as a pickleball court is a 44' x 20' rectangle with a 19' ceiling. There is 5' clearance to walls on each long side and 10' clearance on each end. I can mount cameras in any configuration deemed optimal. Since this is not a security application, the cameras can be indoor only and do not have to be low light capable. I will use a computer to network the cameras. I might even use one for the in/out calls and another for the high resolution cameras.
I want 4k capability with fairly high speed (30 fps minimum) for the 2-3 cameras that record general play. For the line call cameras, I am not sure what resolution is ideal for them but I know they need at least 120 fps. If willing to spend $500 plus for the general play cameras and $100 plus for the line call cameras, what cameras do your recommend for this application?
