Camera recommendation
TheE
Pulling my weight
Dec 8, 2018
194
117
TX
We are about three months from moving into our new home. Our home is about 400 ft from the road. What camera(s) would you recommend to catch vehicles coming into our driveway?
Do you have a straight line unobstructed view from the house to the end of the drive?
400 ft is a log way for most cameras.
So it comes down to what you want to achieve.
If just detecting a vehicle and having the camera alert you to that, sure the B52IR-Z12E-S2 as mentioned by @Chokolinho would do that.
Nighttime is a problem is you dont have light out there. You'll have to get IR out there somehow
The PTZ5a4m-25x PTZ would reach, again not sure IR would be sufficient by itself
You wont be reading license plates with it at that distance, and if you needed to do LPR you'd need to look at placing a camera closer to the entrance @looney2ns is asking
The triple lens may be a possible solution and would cover more of your driveway, but without as much zoom as the Z12
The seawall is 100-120Yds so detecting a vehicle should work fine, minus great detail. But you still need to get IR out there, this scene has a streetlight
192.168.1.110_IPC_main_20250709220859_@1.jpg 192.168.1.110_IPC2_main_20250709220906_@1.jpg 192.168.1.110_IPC3_main_20250709220912_@1.jpg
Oh look. Spam garbage
