If you want to be able to cover the entire room, get the 2.8mm lens...Thanks I'll look into these two cameras.
Basically just a wider angle (you may get a bit of a fishbowl effect with 2.8..but its worth it to cover the entire room) you will lose a bit of detail as the pixel count is spread over a larger area...How do the different lenses affect the picture other than angle of view?
Thanks for the info!Basically just a wider angle (you may get a bit of a fishbowl effect with 2.8..but its worth it to cover the entire room) you will lose a bit of detail as the pixel count is spread over a larger area...
