I would like to place an IP camera looking out at the coast from our condominium. This camera would have no surveillance value, but would like to be able to check surf conditions from work and potentially stream via OBS for public consumption. I use Blue Iris recording 24/7 to a large disk array, and have some experience with relatively low end IP cameras at home and setup for friends. Where we currently live, doorbell camera (Lorex B451AJD-E) is the only camera I have running, as there is really no need for surveillance. Other than just for fun, I want to be sure to record anything interesting that happens: whales and dolphins making appearances, storms, etc, but I'd really like to record the next tsunami if/when it happens (day or night).
Can you recommend a camera(s) and mounting solution?
What I'd be pointing the camera(s) at:
- Shoreline is about 350 feet (110 meters) away. Anything that I care about will occur >90m out to the horizon range. Downward angle to the shore is about 10 degrees.
- Panoramic view of the shore of about 160 degrees, so possibly a 2-sensor camera, but would prefer one camera so I only have one video stream.
- Looking to the NNE, so it only is looking into the sun for the first hour of the day.
- Mounting outside is possible, but due to weather, I would prefer to mount on inside of window. Getting ethernet outside would be challenging due to concrete construction and challenging weather. This would also avoid corrosion issues, which is no joke in this location.
- I've always used PoE, and I'd prefer to continue to do so. However, if I mount inside, it really doesn't matter.
- There is no artificial illumination.
- For OBS streaming (youtube or whatever), would prefer 30fps.
- Do not need the ability to pan (PTZ).
- No need for any image recognition / smart features
- Would be open to DLSR options, but true IP Camera would be cleaner
