Hello peeps.
I need one outdoor cam to view two sides of the house...just enough to cover a wire fence gate and a rear sliding glass door. This cam will be installed under the eaves at a corner soffit which is about 8 feet and a half inches from the ground (see photo and diagram). The gutter downspout might have to be relocated.
I have narrowed down my Dahua cam choices according to preference w/c is the horizontal field-of-view (the wider, the better for two-sided coverage):
1. Dome = 120°
2. Owl Turret =110°
3. Cyclops Turret = 106°
https://www.bhphotovideo.com/c/prod...dbw42a1en_asi_2_8mm_lite_series_2mp_full.html
https://www.bhphotovideo.com/c/prod...y_dh_ipc_hdw42a1en_2_8mm_pro_series_2_mp.html
https://www.bhphotovideo.com/c/prod...dh_ipc_hdw44a1mn_2_8mm_pro_series_4mp_hd.html
Which cam do you think would be ideal?
Since it would be facing directly at the corner where the two walls meet, will this create problems with the IR sensors, focusing, etc.?
I appreciate your suggestions.
1. Dome = 120°
2. Owl Turret =110°
