I have an issue where I can not connect any of my IP Camera’s to my NVR. Any attempt to connect to the cameras with the common passwords (12345, 123456789a, hik12345 or 123456789abc or admin-12345abc ) etc etc give me incorrect password
There is a feature to reset the passwords where you generate a .xml file and send to HikVision support and they send an 8 char code back which you enter to reset the password. Problem is this passcode is not working I get “Password reset fail”
Three questions please:
- Could my problem be that while I was waiting for hikvision support I powered the unit down and then I guess changed the start time for the cameras?
- I assume the passkey that hikvision provide back to you is not the new password itself but the passkey that is used to complete the password reset function – is this assumption correct?
- If the password reset works correctly, what does it reset the password to – 12345?
