J Jahua95 Getting the hang of it May 25, 2020 78 33 USA Sep 19, 2025 #1 Setting up my camera IPC-HDBW5441F-AS-E2-2.8mm I have notice that channel with more light will have larger fluctuation of BPS vs channel with less light. Do I need to play with setting to smooth out the fluctuation ?
wittaj IPCT Contributor Apr 28, 2019 32,306 61,834 USA Sep 19, 2025 #2 You should be using CBR and H264H and that will minimize the fluctuations.
J Jahua95 Getting the hang of it May 25, 2020 78 33 USA Sep 19, 2025 #3 wittaj said: You should be using CBR and H264H and that will minimize the fluctuations. Click to expand... ok
