tangent
- May 12, 2016
- 4,641
- 3,997
mbps is bitrate.Ok I'm still working on a few things with my camera but I wanted to ask if you would recommend changing any of my video settings. Currently the band width is running around 2mbps and I wouldn't mind bumping it up to 3 mbps. I upped the frame rate from 12 to 20 and it didn't change much. Any suggestions? Also I'd like to adjust the picture so the top of his head isn't so burned out. I can't seem to do anything that helps. This time of the evening it's great. Oh and is there anything I can do to make his eyes not glow in the dark at night ? It makes him look evil
I attached a link to a video of my little owl. And I did a screen capture showing the camera settings I have and showing the ipcamlive settings. I hope to figure out how to record to the sd card in the next day or two. Here's my Youtube. He is getting big. https://youtu.be/_Pb7KFsZ590 Thanks in advance for your help. Terri
You could also experiment with VBR instead of CBR.
Picture settings are under Camera > Conditions and are broken down into profiles (day/night). The profile management tab sets which profile is active / when the profiles switch. The default configuration is day all the time with the day profile set to auto day/night.
The manual may be of some help: https://www.dahuasecurity.com/asset...-Web3_0-Operation-Manual-V1_0_0-201805226.pdf
https://dahuawiki.com/index.php?act...a_Web3.0_Operation_Manual_V1.0.1_F_201403.pdf
You can set up recording to the sd card under Storage > Schedule and Storage > Destination
